Does a better computer improve renders
in New Users
I am rendering only in 2D.
Would an improve computer effect the quality of the 2D rendering or would a better computer only
effect the speed of the rendering?
Thank You!
For the most part, it's going to effect speed. You can make a high quality render with an older machine, you just have to wait a week for it to finish. That said, more RAM means you can fit more objects into your renders before seeing some of that horrible slow down. If you have a mid- to high-end NVIDIA card, you'll be able to render in Iray at decent speed as well (limited by that VRAM of course). But technically, no, I don't think it improves the quality of the render. That comes down to technique and patience with the software.
@chanansiegel, Depending on the hardware improvements, they would increase the speed of the render.
I'm guessing you are using default settings at this point. If so, you are rendering with the Iray render engine. There are a number of ways to increase both the speed and quality of Iray renders without investing in more hardware.
The final image quality is the same, whether you render in CPU Only or with the Nvidia GPU. Regardless of your settings an image with 2000 iterations will look the same whether rendered CPU Only or with the video card/GPU. It's just going to take longer in CPU Only, which may lead to stopping the render sooner.
Give these tips a try and see if you like the results.
In the end though, only you can decide which to spend: time or money.
