Mad Nurse for G2 Poser File unzip error?
MouserMouser Posts: 675
The poser companion zip file is not unzipping due to copy file unexpected error:
error msg
!CapeInstructions.duf
Type: DUF File
Date modified: 3/06/2013 1:36 PM
NOTE: I downloaded the file again but get the same result when I unzip it.
Can anyone advise on this?
  • Richard HaseltineRichard Haseltine Posts: 100,833
    It should be a 0 byte file - it's there only to make the PNG with the instructions show up in the library.
  • MouserMouser Posts: 675
    Arebyou saying it should fail to unzip?
    Sorry, I thought you meant it was making a 0 byte fiel and thought that was an error. What are you using to unzip?
    Extracting using whatever Win7 uses by default.
    All the other files have extracted no problem.
    Usualy when I get a problem unzipping a file the file is corrupt or incomplete and I just download another copy.
    But I have re-downloaded the file in question and it still comes up with the error?
  • RodrakRodrak Posts: 81
    Some (buggy) unzip programs fail on 0-bytes files. Maybe try with another program (winrar, winzip etc.) and see if it unpacks properly?
    7Zip is free and worked without error for me on the Mad Nurse for G2F zip.
    7Zip seems to unzip it without issue, I'll call this solved.
    Thanks;)
