Help how to fit new cloth to body
Hello. I made a simple plain cloth in marvelous designer. I tried loading the avatar and the cloth in daz. but when i pose the genesis 2 female the cloth doesnt follow along. i tried the transfer utility under figure. it does fit somehow but with a lot of distortion and bloated the cloth around the breast area. I am not sure why. Also the avatar genesis 2 female i used in marvelous designer for the cloth design had somesort of breast implant using nirvys genesis 2 female breast morphs. These are all the infos i can share. I am not sure if the breast morph are making the new cloth grown bigger near the breast area using the transfer utility. or is there another way to fit/parent a new made cloth the the genesis body?
Thank you for any assistance!
  • Richard HaseltineRichard Haseltine Posts: 102,761
    If you have a morph applied to the figure you modelled the cloth around then in the Transfer Utility you need to click on Source Shape and pick the morph (or pick Use Current), then expand the More Options button and check Reverse Source Shape from Target.
    Another option would be to apply a dFove Modifier to the cloth and do a simulation, with the figure starting at the pose loaded into MD.
  • videoninja719videoninja719 Posts: 343
    edited April 2019
    awesome. thank you @Richard Haseltine . I will try  the technicques you havel listed!
    Post edited by videoninja719 on
