Camera changing
![jdscogin_5266911039](https://secure.gravatar.com/avatar/f0a4a88e019f0ac8a747bbd292106859?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Ff0a4a88e019f0ac8a747bbd292106859_100.png)
There is something I don't understand. I create a camera. Then I save a scene. I change the camera by mistake (easy to do if you don't switch to perspective view. So I reload the saved scene, but the camera has changed. I reload a scene that I saved 3 saves ago, and the camera has still changed. Does saving the scene not save the camera? If so, how do I save the camera settings with the scene? Thanks
It appears that the animation is not saved in a scene also. I guess I have a lot to learn.
Post edited by jdscogin_5266911039 on
a Szene save saves everything
Yeah, you would think that, but does not seem to be happening. Maybe it because I am using 4.6 beta
I am using 4.6.1.7 and unless I Lock the camera it loses DoF settings (enabled/disabled and F/stop) and I seem to recall that the scene retained render size/ratio too, but that, also, is not saved.
