GoZ back to Daz - rig missing
Hello,
Sorry if this question already received an answer, I've litteraly spent two days looking for it without having things workingwell again.
I'm using Windows and DAZ 4.10 + ZBrush 2018.
I GoZ a Genesis 8 character, add little adjustements and then use GoZ to bring it back to ZBrush. First of all the Update options don't show with the Update Morph section, I can only Create a new object. Then it obviously creates a new object, without any rigging, so I can't start animating the new pretty alien created... I'm going mad. The ZBrush Actor tool to choose between the old or the new character is missing as well.
I uninstalled everything linked to GoZ in either ZBrush and DAZ folders, then re-installed it manually. Even tried the Transfer Utility to get my character rigged but it doesn't look like it's made for that as it wasn't successful at all. It was working great some weeks ago, I don't know what I'm missing here.
I would be really happy to go back on my work as I finally enjoy animating with DAZ. Sorry for coming here so desperate.
Thanks a lot
Best
Nora
  • Richard HaseltineRichard Haseltine Posts: 102,759
    Please switch to Smooth Shaded view if you are going to post a screen shot of nude figure, or zoom to show only the upper body for males or head and shoulders for females.
    Was the figure sent over at base resolution? Did you use tools in ZBrush that chnaged only the shape, not adding or removing any geometry?
  • nora1020nora1020 Posts: 0
    Sorry for the screenshot and thanks for your answer.
    I did not changed the resolution of the figure nor the geometry from ZBrush. Just modified the body shapes and smoothed it with the ZBrush tool...
