Where do I get the UV map if it isn't included?
I need the UV's of these clothes https://www.daz3d.com/slinky-suit-for-genesis-3-female-s
but there aren't any templates or any UV texture included when I downloaded it. I can see an UV map in the UV view though. How do I get the UV map out of there so I can edit it in photoshop?
Also bonus question: When I make a cylinder from create, new primitve I also find an UV map for it, where can I get this one out of daz3d?
Post edited by Illidanstorm on
I use UV Tailor. You can save a file as large as 4096 pixels, but if I recall correctly, it won't enlarge it if the original texture is less than what you specify.
Is there another way? I can't spend 30$ on this.
You can use blender to extract the UVs if you first export the clothes as obj.
If you are simply after a template, would it be good enough to go into UV View, hit Shift+F11 to go into full screen mode, and then ake a screenshot?
Or load the obj into UV Mapper Classic and save your templates from there
UV Mapper Classic is free: http://www.uvmapper.com/downloads.html
mCasual also got a script for that mcjTemplate.
