Looking for good lights
in New Users
Anybody that can recomend a product that achives good light for skins. Mostly skin comes out
glossy or greyish with noise when i use Default settings in Daz Sun-Sky only or
Dome and Scene. I tried adjusting Tone mapping but if the skin gets clear and natural the
envirorment is too bright!
... And yes i tried reducing Glos in the Surface tab!
Top coat is another thing to try adjusting. Unfortunately PAs vary quite a bit in how they make the skin look, which can geenrate cofnlicting appearances or mean that a character doesn't meet your needs. One thing you can try is aplying the materials preset for a skin you do like, holding down the cmd (Mac)/ctrl(Win) key as you do so and then selectign Ignore for Maps in the dialogue that opens - if the two use the same kinds of map then that may make the result closer to what you desire, though you may need to experiment to find combos that work (with luck once you do you will be able to use the saem preset as an override for all materials from the same vendor).
