new grapics card
shankshank Posts: 29
hi i just got a geforce gtx 1660 ti 6gig grapics card. but when i render it still goes 99 to a 100 on cpu. the gpu 2 to 4 percent max.even if i used default standard setting for render. any ideas?
  • Richard HaseltineRichard Haseltine Posts: 102,759
    Which version of Daz Studio (assuming this is) and which driver version? Despite the number I think this is stil a 20x0 card in effect, and so needs the 4.11 beta
  • LenioTGLenioTG Posts: 2,118
    Try to download GPU-Z and to see how much VRAM you're using: if you go over those 6Gb, you'll have to use your CPU. And it's almost never 6Gb, because you might be using it to display your OS too.
    If you did a test render and you left that window open, your VRAM will not clear. And sometimes it doesn't clear either while you use Daz. The best way is to just restart it before rendering :)
