Bridge Icon in 8.5?
![timrisher](https://secure.gravatar.com/avatar/051549d9c938997851c38a798a5cb507?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F051549d9c938997851c38a798a5cb507_100.png)
I am wondering what has happened to the bridge icon? I was using it in a function to create 3d walls of certain thicknesses by duplicating a plane and then bridging them. Is the icon hidden or changed? Thanks.
No, still there in the vertex modeller where it used to be!
is it pro or standard?
I have Pro, I'm not sure if that is one of the features that is Pro only. I am assuming if Tim used it previously then he will have upgraded to a similar version.
By the way, to make a wall from a plane, you could just use the Add Thickness menu command, this is simpler and cuts out a step.
Thanks for your replies - I only have the standard Carrara. I upgraded, however from the 8 to the 8.5, and either I've done something wrong, or the icon was removed from one to the other. Thanks for the "thickness" command, though. I didn't know about it, and it is definitely much easier!
I found this that does indicate that the bridge tool is a Pro-only feature.
http://www.daz3d.com/products/carrara/carrara-tech-specs/
