DARK ARTS Time Particle Shader
richard.chaos_91798ec102
I have been watching Mark Bremmers Tutorial DARK ARTS about the particle Smoke Shader. He uses a Particle Shader MIXER and sets it to time. BUT as far as I can tell there is NO way to assign or set the TIME for anything? What am I missing?. Like one wants the color of the particles to change over TIME but I can see no way to SET that time
I remember that tutorial and it worked well from what I remember. The time factor I thought was based on the particle life.
Yes, I believe you are correct. The time in the shader is the life of the particle which is set in the emitter's editor.
I assume this is regarding our question about the rockets red glare ...
The time is the lifespan of the particles.
I found that using a color gradient you can easier control the color transition.
AHH I SEE THE TIME IS SET IN THE PARTICLE EMMIT AREA
