Luxus for Carrara: PDF-manual, DIM and C8.5?
FetitoFetito Posts: 481
Hello!
1) Luxus for Carrara has a PDF-manual?
2) Does the actual version work well with Carrara 8.5?
3) Does it get installed via DIM?
  • rk66rk66 Posts: 438
  • PhilWPhilW Posts: 5,145
    ...and its on sale at 50% off! Very low cost for a new render engine to use with Carrara.
  • ilnyneilnyne Posts: 29
    Is anyone else having installation problems with this? I just purchased it and can't get it to install. When I open the setup file, it runs for a few seconds, then disappears. Eventually, I was able to get it to run all the way through, then I installed the standalone LuxRenderer for my system (Windows 64 bit), but when I open Carrara, there is no option under my render tab to use Luxus. Is there some kind of manual way for me to do this, or at least check and verify that the files installed correctly?
