How to close eyes on G8F
If I dial the "closed eyes" morph of genesis 8 female to 100% it looks like this
At 75% it looks like this, there is some white spots at the inside
On the right side is G3F with 100% eyes closed. Is it just me having this problem or how do I close the eyes?
Post edited by Chohole on
This is G8F with eyes 100% closed on my system.
The dial's range standard goes to 125% closed, and that would give the result I see in your 1st image.
Not for me.
It looks like that at 100%
My guess would be some other morph is interfering; Sometimes that happens unintentionally (can't really explain the technical details)
Did you check if any other morphs are dialed in when youload the base G8F? ( Parameters tab for the G8F figure - Currently Used)
Yes, there aren't any other morphs dialed in.
Ouch, maybe there's a character morph that alters and replaces the eyes closed 'morph/shape'. I haven't noticed this kind of probelm with G8F yet, but did have a similar problem with G2F (IIRC) were installing a (in my case a freebie) character messed up some morphs for the base G2F....
Ok, I found the issue.
I looked at the log file and it loaded a morph named "MCMYIYIEyesClosedR" and "MCMYIYIEyesClosedL" by someone named Hamster. It was not visibel under the parameters. I deleted it and now it works again. Thanks!
Good to know you found it. Based on your comment my guess is then it's this character
https://www.daz3d.com/yiyi-and-expressions-for-genesis-8-female
if so, then it might be a good idea to open a support ticket and report this problem...
In the Parameters pane option menu (the linked button in the top corner, or right-click the tab) enable Show hidden properties and you should see the morph in cases like this - presumably soemthing is either saved with a non-zero default, or isn't properly linked to the main shape so it kicks in for all eye closing. Check to see if there's an update, if not (or if that doesn't help) open a Technical Support ticket https://www.daz3d.com/help/help-contact-us as glaseye suggested
