TDLMAKE AGAIN!
PatroklosPatroklos Posts: 533
It makes Sickleyields Dirty Denim almost completely unusable, and M6 Intimates slow & jerky, is there really nothing that can be done?
I can't disable it as multiple versiond run.
Any ideas anyone?
  • Richard HaseltineRichard Haseltine Posts: 102,724
    tdlmake is optimising images - it has to run or you can't render. How long is it running for? If this is a continuing issue about which you have posted before you'd do better to add a new post to that thread rather than start a new one.
  • PatroklosPatroklos Posts: 533
    The problem is that nothing said last time, in April I believe, made any difference.
    Maybe I should report the problem as a bug?
    If you do that (open a support ticket fro technical Support) it will be reviewed by support and they should either provide advice or pass it on to the developers. However as I recall you are having problems that don't affect other suers, at least not to such an extent, which will make it hard for either support or the developers to deal with - but if it is a bug, even one that affects only a subset of users, it does need to be reported.
