Help with Wet and Wild?
I got this product...I don't remember when and just came across it in my library so I decided to play with it. It looks like it will look great but I'm having a bit of a glitch with it and was hoping some experiance here might point me in the right direction. In the attached picture, what am I doing wrong?
281 x 469 - 27K
It looks like the product was applied to the eyelashes part and it removed the lashes texture and transmap, making them solid white. You can fix that by simply applying another material to the lashes.
Edit: double post
Turn the lashes off in the Parameters pane for the Geometry Shell. There should be a list of groups with an on/off button for each
Perfect, thank you both!
