Reboot your scenes - Delete all animation keys on all nodes
https://sites.google.com/site/mcasualsdazscripts9/mcjunanimatewholescene
Use
set the current frame to the frame that has the poses you like
run the script
There is no UNDO
here is the code that is being run
DAZ SCRIPT
var mgr = MainWindow.getActionMgr();
var funcA = mgr.findAction( "DzMemorizeSelectedItemsAction" );
var funcB = mgr.findAction( "DzClearKeysSelectedItemsAction" );
var nodes = Scene.getNodeList();
Scene.selectAllNodes( false );
for( var i = 0; i < nodes.length; i++ )
var node = nodes[i];
node.select( true );
funcA.trigger();
funcB.trigger();
node.select( false );
182 x 182 - 50K
Post edited by mCasual on
Hi!!!
Thanks for the very useful script! I have one request. When I run the script, all the numbers in the scene, such as character and object parameters, are defaulted.
For example, if character A's position X is 10.0, it means that x10.0 will be the default after script execution. Can you tell me if there is a solution?
