Animation for surface tab timeline not working
HI all,
I was wondering if it's possible to animate on the timeline with stuff from the surface tab.
Here is what I'm doing, currently working with Star Trek's U.S.S. Voyager from http://www.foundation3d.com/index.php?categoryid=38&p13_sectionid=307&p13_fileid=1556
There are navigation lights on the ship (as a normal plane has too) I want then to blink during my animation flyby.
Was trying to do it a simple a setting a frame with lumination on 8000 and turning it too 0 on another keyframe.... and then back again on another ket frame.
See the attached print screen.
But those keyframes aren't set or active. not even when I do it manually.
Can anyone tell me what I'm doing wrong? or isn't it possible at all?
The light is a surface texture only it's not on the scene itself
Like if you could blink eyes of a model, select the yes... do open close on the parameters tab. this can't be done here.
The model ship is from a poser.
Thanks in advance.
Cheers
Normal lights like spots would work, but since you use emissive surfaces it's not straight forward. I believe you need to use a script to be able to animate surface properties in DS. You might want to check the forums freebie section, IIRC mcCasual has made one, don't have a link at hand though. Or as a simple workaround, use two copies of the ship, one with emissives on, one with emissives off. For lights on, scale down the copy with emissives off to 0%, for lights off, do it the opposite way etc.
Not very elegant solution, but should work.
Found the link to MCasuals script https://sites.google.com/site/mcasualsdazscripts/matanim.
Not shure if it will work with emissive shader values. This screenshot looks promising I've never tried it.
Ok, can anyone help me out here on how this script should work?
Maybe someone can try something similar to my case and tell me if it works?
And then a step by step description? that would be great.
Thanks
I've tried this on a primitive plane that got the Iray Uber Base Shader applied. It should work like this if I get it right.
This was working for me I don't know if those material animations will get saved in the scene file. There is also mcjAniMatSave to deal with that issue.
If anything else failes create a Point Light, the Light Intensity slider is animatable by default. Parent the Point Light to the USS Voyager and position it to match the navigation lights. Turn off the emissive surface settings.
There will be keyframes showing up in the timeline for the Point Light to animate. I would first create the lights on keyframe then some frames later the lights off keyframe. Then select the lights on keyframe go to Edit>Object>Menorize Selected Item now you can use the memorized state, go to another frame to create a pulsing light and place a new key frame with Edit>Object>Restore Selected Item the item will restore to the memorized state. Edit>Object>Clear Item will remove all keyframes fom this object.
I installed the script to give it a go, tks for the link:) It worked, except for the "set tweening for current frame". It always used the splined model. However, the "set tweening for all keys" worked as expected.
SO im trying to create this blinking navigation light but this is done with luminance and not with emission temp.
Now... i got the time line to animate, the light stays on... but flashes bright for 1 second after ever 3 seconds, although this is the intent.
So at 60 fps 1 sec = 60 frames and 3 sec = 180 frames.
So the first 60 are ok... i go from frame 0 (15000 lumen) to frame 30 (320000 lumen) to frame 60 (15000 lumen) but now here it come... when adden at frame 240 another key frame at 15000 lumen and then at frame 270 320000 lumen and at frame 300 15000 lumen the animation work between frames 0 to 60 and 240 to 300. But between 60 and 240 which should stay steady ad 15000 it also animates,,,,go from 15000 to -15000 and back to 15000 (see attached picture)
So what am i doing wrong?
The key at frame 60 needs to be set to constant or linear. Only, I mentioned in my previous post that I couldn't get it to work, only the "set tweenning for all keys" worked for me. Try setting all keys to linear and see if it works for you.
DAZ really are behind everything else not implementing animated textures and even just animated procedural surfaces natively
all the Dforce and strand hairs in the world won’t make up for this basic render software omission
understood maybe it was a limitation of 3Delight yet Casual and a couple PA’s too managed to create scripts which apparently work on iray too so it’s a pretty basic function they chose to ignore.
BTW I hate using scripts so I just do multiple render passes and animate it in Hitfilm if forced to used DAZ studio
well I would render the whole thing with light on and off and layer the the two in a composite shot and animate the blending
Did you try this? mcjAniMatSave
Not sure...maybe you made the key at frame 240 constant by accident? Should be linear. Btw if you have added keyframes for 15000 luminance at frame 60 and 240 you could use linear for those. Infact for all the keys. If that doesn't work either the script is broken or something else is messed up. You shouldn't need to do it, but if there's a bug around, try adding another keyframe at 241 with 15001 luminance, set it to linear. That's all I can come up with atm;)
You probably grasped it already, but just to be sure: Constant means the value stays the same till the next keyframe then jumping to the next value. Linear means...well linear transition between keys, so going from 15000 to 15000 is practically the same as constant.
aaaaaaaaaaaaaaaaaaaaaaaah thanks Sven, that did the trick adding an extra key frame at 239 (constant from 60 to 239) and key frame at 240 linear... that did the trick..... now all is moving.
Going to render that over night 600 frames, daz studio 4.11 with denoiser on at 8 itterations, 300 itterations per picture and quality off. at 1080P this setting gives me no grain and is the best setting to render for. lowest render time is around 30 sec and highest just above 1 min. looking forward to wake up tomorrow and putting it quickly adobe premiere and play the animation ;)
Thanks again Sven and yes the save animation tool comes in handy too ;)
Ok so how does that " mcjAniMatSave" actually work. I've tried to save it, it saves to a *.dsa file. So when Daz studio is closed and I reopen Daz with my normal *.duf safe file how would I implement that *.dsa file to get the animation working again?
Happy to hear it's working:)
Actually...no idea! Do you select teh object(s) with the animated surfaces and launch the script file? I haven't had the time to play with it yet, let me know if this works, if not I'll have a look at it soonish:)
It saves like kind of a material preset.
After loading your scene just select the object you saved the animation for and apply the .dsa file to it. That‘s all you have to do.
@xXQuatroXx
Great that you figured it out. I also must have pressed "set tweening for all keys" once before it was working for me. Getting the interpolation between the keyframes right is something you have to deal with all time while animating. It's hard enougth with regular object/figure properties where you can see the keyframes on the timeline but with material animations it seems you can only guess how the value change curve will look like.
In case you don't know DS got the keyMate and graphMate plugins for animating, the later is for working with animation curves but not with material settings. I think I heared somwhere that there is a ainmate material node in the ShaderBulder somwhere.
Here is another great script for those situations where you don't want to have your materials animating. mcjFreezeMaterials Happen to me sometimes in scenes where I'm at some keyframe where my figures are propably posed and then I start to make test renders and tweak the skin shader settings for example and then they start to change over time.
For some reason maybe securety related you can't "execute" a script directly by double clicking the icons in the Content Library pane. You have to right-click and choose "Open in script IDE" that will open the scripting pane with the big Execute button on the top right to run the script. Well that is one oddity with scripts in DS, I tried as you did with drag and drop both from the Content Library into the Viewport and into the Script IDE pane but nothing of this works.
It's common to use those *.dsa scripts even for loading additional things with the content *.duf asset files. As far as I know there is only one save option with the Character Preset that offers you to select a so called Post Load script. It somehow writes a reference to that dsa file into the duf preset file. I found this option could be an iteresting way to load contet but I didn't made use of it yet. Uncheck the Compress File at the bottom to have a look at the duf file lateron in a tex editor where you could see the additional Post load script reference somewhere if you search for your script file name.
Post-Load Data Items
[PS]: Lately I had a look at the script examples in the documentation center and found those script examples under "Post-Load Data Items". I'm not shure what they do but as I understand the script code they have something to do with creating a proxy object like a null node and "link" some animateable properties of this object like translate y for example with some shader related property. If I think further this would enable you to animate the curves of those proxy object in graphMate and control shader settings with this.
this is a bit too acadabra hocuspocus too me ;) LOL i hope you can find some time to figure out on how to save it ;) thanks for all the time you have spend on this already.
Sorry I forget all those scripting API References I've posted dosn't realy belong into the New Users section. Usualy if you ask here in the forum for a scripting solution for a complicated task eventualy they simply post an url like this: http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/start
I actualy wanted to give you the advice to save your voyager space ship as a Character Preset to your Content Library and select the dsa script that you saved with mcjAniMatSave as the Post Load script in the save dialog to load the material animation you made so far with the ship into any scene. I am thinking of how you could loop the currently keyframed lights blinking material animation maybe you could bake it to an aniBlock.
Create Your Own aniBlock - YouTube
You know animation gets alot easier if you have seperate layers with aniblocks in the aniMate2 pane. Move the ship in one layer and repeate the short blinking material aniBlock on a seperate layer - if that is even possible - to have a blinking light during the full Play Range in the timeline.
[Edit1]: That is how to loop aniBlocks: Applying Animations in Daz Studio's aniMate2
[Edit2]: Here is MCasuals curve editor mcjSceneGraf for DS4.5
This is why I never bother with it
my softwares of choice all do animated textures out the box, anything I do in DAZ studio only because I have no choice it’s a software specific item gets composited into something else or used in Carrara, iClone or Poser or even Blender as an animated texture on a plane!
DAZ studio has two things going for it, it is free and all DAZ content works with it so not knocking it just accepted long ago it’s limitations.
There is nothing wrong with composition, Weta does it, watch their YouTube videos, only DAZ hobbyists try to do everything in the one program.
Is fine you are not alone there, I find most DAZ studio users don’t like to venture out of their program
Those that do (especially to Blender which I admit is too difficult for me) wonder why they didn’t sooner.
I did not of course start with DAZ studio, I was an iClone 3 user back in 2009 then Carrara and Poser user so I never felt the safety of being in the box
Was not suggesting you get Carrara as that’s more of an all round modelling software with physical particles, terrain and tree generators not a content load pose and render studio.
As you said if sticking to buying and rendering DAZ content not your best choice, if importing FBX figures etc from other softwares it blows DAZ Studio out of the water as that simply cannot.
The Enterprise model of course would also work perfectly in Carrara and countless other softwares, why when you have no DAZ figures outside you want to fight to do your space scene even in it is beyond me TBH.
