[Released] Skin Doctor - Dirt & Grime for Genesis 3 and 8 Males [Commercial]
RiverSoft ArtRiverSoft Art Posts: 6,646
Skin Doctor is a panel and script-driven skin add-on solution consisting of different modules. Each module can work stand alone, it is not needed to have the other modules. Modules can also be combined of course. Skin Doctor - Dirt & Grime for Genesis 3 Male(s) and Genesis 8 Male(s) integrates seamlessly with Skin Doctor - Blood and Bandages for Genesis 8 Male(s).
The Dirt & Grime module provides 44 dirt/grime geo shell options for Genesis 3 and 8 Male based characters.
The Skin Doctor Editor manages all the minutiae of selecting and creating geo shells, materials, and surfaces while allowing you to change the colors, locations, and intensities of the various skin options easily and quickly. While other products provide you with 5, 10, or perhaps 15 presets to change colors or intensities, the Skin Doctor Editor provides an UNLIMITED number of intensity or colors options to craft your perfect skin look. You can, for instance, have the dirt options look like mud, dry dirt, sand etc.
For this module, you can use the Skin Doctor Editor to adjust the dirt/grime color to any color you want and the opacity with a step less dial. You can also easily move the geo shells to get them in that perfect position. Several ready to use presets are also included for your convenience. Each applied shell can be hidden or shown individually and also set up individually with the Editor.
This product is supposed to be used with Iray only.
Features
  • Skin Doctor - Dirt & Grime for Genesis 3 and 8 Males (.DUF)
  • Skin Doctor Script:
    • Blood and Bandages Compatibility Tabs:
      • Use of the following tabs requires Blood and Bandages to be installed!
      • Bandages
      • Band-Aids
      • Blood
      • Wounds
    • Dirt-Grime Tab:
      • Preset Options:
        • 10 Faces
        • 08 Arms + 01 Fingernails
        • 07 Legs + 01 Toenails
        • 16 Torsos
      • Geoshell Options:
        • Show/Hide
        • Opacity
        • Color Selection
        • Horizontal/Vertical Offset
    • Options Tab:
      • Geoshell Offset Parameters
      • Editor Options
  • Manual Preset Options:
    • 10 Faces
    • 08 Arms
    • 01 Fingernails
    • 07 Legs
    • 01 Toenails
    • 16 Torsos
  • Textures Include:
    • 129 Texture, Bump and Normal Maps (4096 x 4096)
  • Optimized for Iray
1000 x 1300 - 326K
1000 x 1300 - 547K
1829 x 1000 - 412K
1811 x 1811 - 773K
1811 x 1811 - 738K
1811 x 1394 - 710K
1000 x 1300 - 333K
1000 x 1300 - 382K
1778 x 1000 - 508K
380 x 494 - 121K
Post edited by RiverSoft Art on
