Ready ! -- mcjSetRotationAxis - script to set the rotation axis of props and objects
Ready !
manual and download here
------------> https://sites.google.com/site/mcasualsdazscripts3/mcjchangeorientation
as you could see in the movie "it's tilted, babies" ( https://www.youtube.com/watch?v=GDGXSmuEr0U )
sometimes you need a hinge rotation axis that is not vertical and not horizontal
for car doors notably
it could possibly be useful when building low poly prop-figures ( stickman )
i'll see if i can also make it helpful for steerable car wheels
Agent Amy Hanging out near the ice merchandiser
( includes tilted hinges, babies )
1920 x 1080 - 382K
1920 x 1080 - 249K
1920 x 1080 - 1M
Post edited by mCasual on
That's a great idea! In the past, to make Steering Wheels, I had to parent it to a Null for the rotation!
that time when agent Amy kept opening and closing the ice merchandiser's tilted hinged door
gotta finish this tilted-hinges script,
then the plan is to quickly wrap up the Amywagen ( volkswagen pickup )
then have the physics simulation thing ready for xmas, so people have something to play with at 4 am on Dec 25
in case a programmer ever wants to do something similar
the source code to change the orientation ( y axis ) of a node ( door )
based on the vector formed by two nodes
as a bonus the node having its orientation changed
does not need to have its transforms zeroed
and this code snippet is used to change the location of the node's origin
for the test case the subject ( door ) was moved away from its load-time position and was rotated 45 degrees
The User Interface in DS3
and the steering for upcoming tests
new improved fidelity steering for the Amywagen
( the reference being 1967 bus / pickups
on some VW items there's the coat of arms of the city of Wolfsburg - a two-tower castle over which paces a golden wolf with a blue tongue.
when you use a primitives/cylinder as a tire
the x y z axis don't allow you to have the wheel roll and remain steerable
but using this script you'll be able to reorient the Y A xis
and get the roll & steer without having to use nulls
a sad thing is that yesterday was it, i had almost completed the script when Daz Studio crashed on me
and apparently i never saved this version !
the silver lining is that it's much faster to re-write it than it was to write it
oh my i was almost forgetting i have to do finish this script before resuming work on the Amywagen, then get back to the physics toy
new mirror !
which incidentally may require use of mcjSetRotationAxis for the rigging
Someday soon i'll publish a new version of mcjAutolimb ( an indispensable DS animation tool if i can say so myself )
with auto-spin !
but for now today i'll complete mcjSetRotationAxis
complex test case for the axis re-orienter script
the Amywagen mirror
it worked well but only when thee 3 elements of the mirror assembly were in an unrotated state to start with
so i have to re-discover the code that i used for the Ice Merchandiser door test
WOW, this is going to be useful!
hoping to post it today
then on to the Amywagen
I'm getting dizzy watching Aiko!
so this script can re-orient an object's Y axis anyway you like
but the 2 other axis of the "rotation frame" can not be left to chance
so i will add the "then orient the X Axis according to" options
it will spin the rotation frame about the new Y Axis
Looks cool.
By the way, have you ever written a script that would reposition a prop's world rotation? You know sometimes when you load a prop and then try to move it around the rotation seems really off, like the prop fly's away from the position it was previously in? I've always hated when that would happen, esp in 3D space, you just don't know sometimes where the hell it went! lol Might be useful!
adding all those options gets a bit confusing
but it may let you rig a custom prop just the way you want
in this case the Y Rotation Axis ( green circle ) of the object was re-aligned along the World's X axis ( red arrow )
and the X Rotation Axis ( red circle ) of the object was re-aligned along the World's Z axis ( blue arrow )
WOW cool beans, so this script may do what I was asking too?
see in the user interface of the upcoming script there's a button labeled "Set Origin To Marker 1"
this means you could position and select a null node, then select the prop,
and the script would place the prop's origin at the location of the null
for years what i've been using for this task is the MoveOrigin script by DeltaX15
http://www.4shared.com/dir/722776/10801f63/DS_Scripts.html
but i also saw that Daz Studio 4 has new sub-menus where you can change a node's origin
https://www.google.ca/search?q=moveorigin+script+daz&oq=moveorigin+script+daz
also shown in the image below, rotating the rotation frame 45 degrees using the "angle" slider
the finishing touch, i added the "three markers" mode
the line going from the first selected marker to the second gives the prop's new Y-Rotation axis
and the line going from the first selected marker to the third gives the prop's new X-Rotation axis
( the script forces the second vector to be perpendicular to the other )
Looking forward to this release.
Is the VW still in production?
new improved code to change the origin of an object, but without disturbing its position
image below for decorative purposes
that's what i was calling the Amywagen
once i'm done with this script ( today for sure! ) i get back to the Amywagen
and the hope is, this will be followed by an improved version of the physics simulation kit, in time for Dec. 24
old unrelated pic for decorative purposes
Oh my!
it's done and i can return to modeling the Amywagen ( 1967 Volkswagen Transporter )
i did a few tests of the script while writing the manual
so it should work :)
there --------------------> https://sites.google.com/site/mcasualsdazscripts3/mcjchangeorientation
WOW... awesome. Did Larry actually have a conversation with that cat? lol
Thank you ;-)
well not really though i'm sure Larry had guests like Kermit :)
( didnt spend too much photoshopping effort of some images back then )
Hehehe... Mysterio Cat!
That's so good!:)
