Bryce 7 Pro aspect ratio ??[SOLVED]
ed3Ded3D Posts: 2,260
edited June 2019 in Bryce Discussion
_and to have particular  bryce 7 pro  aspect ratio ??
+16 : 9+
seems to have some trouble about it _
Post edited by ed3D on
  • HoroHoro Posts: 10,772
    ed3D - not sure what you mean. File > Document Setup (or Ctrl+Alt+N) lets you set any document aspect ratio. Untick Constrain Proportions and enter in the Document Resolution fields the width x height in pixels. Or enter the Document Aspect Ratio width : height. If you enable Constrain Proportions you can then set either the width or height in the field and the other one is calculated according to the aspect ratio entered.
  • ed3Ded3D Posts: 2,260
    Horo:  +alright then _ Thanks kindly +
    _did come up with An Solution since , asking this Question   +Was shooting for  3840×2160 (4K)
    ed3D - So it helped. Thank you for reporting back.
    edited July 2019
    + don't know what the trouble  was   _ after  Your remark ,  went tryed again  And came out right
    solution was To crop  , cause wide was right and height was over ,  Like 'about 2300   or some such
    _thanx  again +
