How to Undo?
dHandledHandle Posts: 617
Is there any easy way to undo the last change I have made, regardless of what it is?
It seems like there are some changes that I can't undo. Also, I haven't found a redo button yet. Like..I make a change...undo it, then put it back again with a simple keystroke. (ctrl z = undo change; shift ctrl z = undo the last undo and restore. (like in After Effects, Photoshop...Microsoft Word, etc)
Should be a standard and simple thing to do.
I make a small change in something...but when I ctrl z, it doesn't undo what I just did; instead it will undo the last clothing item I put on the model 20 minutes ago, or something else unrelated.
Very frustrating!
I just lost my patience and deleted a scene I have been working on for the past 2 hours (without saving!) because these small irritations stack up and constantly interrupting my creativity to deal with interface work-arounds!
/sigh
Thanks in advance...
"D"
    Note that if you are using the Perspective or one of the other viewport views, this is not recorded to the Undo stack. If you create a camera and use that then Undo will work on those actions.
    Also, I haven’t found a redo button yet. Like..I make a change…undo it, then put it back again with a simple keystroke. (ctrl z = undo change; shift ctrl z = undo the last undo and restore. (like in After Effects, Photoshop…Microsoft Word, etc)
    DS4.6, Edit > Undo (Ctrl+Z) and Edit > Redo (Ctrl+Y) that is what most programs use
  • dHandledHandle Posts: 617
    Thanks guys! Didn't know that about cameras. Very helpful!
