Does this product speed up G3 to G2 skins into Carrara?
3drendero
This DS only product is on sale today and I always wondered if it can be used to speed up G3/V7 to G2/V6 skins in Carrara? By using DS as a preparation/conversion tool. Any ideas?
Genesis 3 UVs for Genesis 2 Female(s):
https://www.daz3d.com/genesis-3-uvs-for-genesis-2-female-s
For example some new Iray skins with Philemos plugins.
no because it uses Geografts and Carrara has UV mapping broken by geografts
you can only do the bits not geografted as the vertex count and surfaces don't match on the geografts
I did try it
basically your collars and thighs need to be covered
I do have some of the ones for Genesis 3 and 8
with those if fully clothed can leave off the geografts and save as a UV set for Misty's characters
cannot be bothered buying this one even at 299c
For redoing skins
I use Ultimate Unwrap 3D repaint
you can also use a pared down version of Blacksmith 3D at Renderosity that just does this
unfortunately as these are offsite commercial products there is not much information I can link
