Simple clay render style background
swoobyswooby Posts: 9
How CAN i get an simple white/grey clay render style background for my Animation. E.g. Like this one he in the youtube example videos: https://www.daz3d.com/everyday-moves ?
  • Richard HaseltineRichard Haseltine Posts: 102,745
    A simple way would be:
    1. Create a new primitive (that will have a basic shader set-up)
    2. Click on it with the Surface Selection tool (to select the object and its only surface)
    3. Optionally try adjusting settings in the Editor tab of the Surfaces pane, to get something closer to your desired look
    4. File>Save As>Shader Preset
    5. Select teh item you want to modifiy, in the Editor tab of the Surfaces pane click its name (this will select all surfaces)
    6. Double click the shader preset you saved at step 4
