Mac user having problems when export lip sync .mov file
thisisracothisisraco Posts: 0
Hi everyone!
Sorry if this has been asked already, tried to look through all the threads carefully, but might have missed,
I work on a mac and followed a couple of lip sync tutorials with daz3d 3, which totally worked for the animation i needed (just victoria saying one sentence)
but once i render it, it won't play on any of my players: quicktime latest version, quicktime 7, vlc, even tried windows media for mac as the tutorial was on a pc.
Anyone had had this problem and knows what to do?
Any help will be greatly appreciated :)
Thanks!
  • Richard HaseltineRichard Haseltine Posts: 102,727
    Try rendering to an image sequence, then turn the image sequence into an animation - that's generally much more reliable, as well as more flexible.
  • thisisracothisisraco Posts: 0
    Thanks! then i should use an editing program to add the audio afterwards?
    Is there a more direct way maybe?
    Also since it seemed to work on the pc tutorial, is it a problem of me using a mac or the codec used by daz, is there anything i could tweek?
    thanks again!
    Rendering to AVI or QT is always risky, doesn't save an alpha channel and makes it hard to correct errors or glitches - I don't know if you are hitting a bug or if it's something to do with your settings but I always advise using an image sequence anyway.
