ready! - mcjShiftAnim - synthesize and modify existing animations
---------> manual and download
https://sites.google.com/site/mcasualsdazscripts3/mcjshiftanim
this script is very much like mcjCycleFilter
but doesn't have the graphical display ( and the associated sluggish response for long play-ranges )
it can modify the animation of any (float) property or morph channel for a given node
̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_̲_
History
December 14th 2013 8 PM -
- fixed issue with the extremities of looping-time-shifted.
- implemented the ‘‘curPos’’ constant and the ‘‘pos’’ variable
December 13th 2013 - Released
example :
you found a dance animation but the dancer's feet are below ground level
with mcjShiftAnim select the figure's hip node
specify you want the YTrans parameter to be shifted 4 (centimeters ) up
the script will go through the entire play-range and apply this change
example, you have a dancing character, the arms are going up and down,
with the shoulders "bend" angle going from angle 20 degrees to 40 degrees
you could use mcjShiftAnim to keep the same movement, but raise the average arms height by
by adding 10 degrees to the bend angles
the script can also set a joint angle or a morph strength to its current-frame value or a value of your choice
and that's done for each frame of the play-range by the script !
there is also an expert mode wherein a programmer can type in a formula
example, i select the Bend angle of a shoulder
i type
val = 30 + 30 * sin( 5 * ang + pi / 2 );
and the arm will now gracefully bat at a rate of 5 cycles per play-range
the bend angles will range between 0 and 60 degrees
for important animation effects like
- Anticipation
- Follow through and overlapping action
- Secondary action
one often needs to shift a limb animation in time
when building a walk or dance animation cycle we work on looping curves
the last frame of the cycle must remain the same as the last one ... it's a loop
so i added the ability to shift in time an animation curve without destroying the loop
technically that's called a rotation
there's will also be a function to shift without looping
note that the mcjReTime script is better suited for cases where you want to time shift a whole pose-animation
https://sites.google.com/site/mcasualsdazscripts2/mcjretimeanimation
same animation
i repeated it 5 times using bLooper
i added a sinewave motion to the YTrans of the hip node using the upcoming script
i used mcjAutoLimb and mcjKeepOriend to "re-attach" the feet to the ground
oops actually i replaced the vertical movement instead of adding it tp the original bouncy movement
here the little shocks in the animation may be due to "aliasing"
because of the low frame rate of 10 fps
the vertical motion was created using the "expert" mode and a function like
there !
i removed the hard-knock movements from the hip rotations using mcjShiftAnim's simple 3-samples box filter
oops ... error
working on it
well unfortunately i had to use good old mcjCycleFilter to filter/smoothen the animation curves
but i'll fix the issue that caused the problem
looks quite good though now
figure 2 : the hip animation curves for this dance
( rendered using WebGL ! exported from daz using an upcoming-in-2014 script )
( meaning it's Mac compatible ny the way )
i'll add a way to load save and reload the custom functions
hula up
added load/save function
so if you created a formula like
you can save it as fx_FlooredSine.txt
and re-use it at a later date
( this formula was used to add some movement to the chest node's Bend channel
and the side-side channel used
since this is an additive effect ( val = val + ... ), i did not wipe out the important
chest stabilizing work performed by mcjKeepOrient prior to this
skillz
( and resistance to cold )
ready !
and here you can see it also works in Daz Studio 1.8
i developped it in Daz Studio 3
still got to test it in DS4 !!! ... you never know
( i mean, I never know )
so now the plan is, finish the Amywagen ( 1967 volkswagen transporter )
then have the physics engine toy ready for xmas eve
* Update ** Update ** Update ** Update ** Update ** Update ** Update ** Update *
- implemented the ''curPos'' constant and the ''pos'' variable
the looping-time shift is very important for cycling animations, since it helps you tweak anticipation and follow-through
in figure 2 i used mcjShiftAnim to animate the balls using the "Set" processing and the "Parameter"
( actually i used parameters locking and mcjParent to copy the first ball's Z motion )
then i used mcjShiftAnim 's Looping-Time-Shift to delay the animation of the balls by, respectively, 5, 10, 15, 20, 25 frames
added the instruction manual as a pdf
https://sites.google.com/site/mcasualsdazscripts3/mcjshiftanim/mcjShiftAnim_manual.pdf?attredirects=0&d=1
