DUF file not visible in Runtime Props directory
3dOutlaw3dOutlaw Posts: 2,471
If I save a figure/prop in Studio out to a new folder in my runtime/libraries/props/subdirectory...should it be showing up, or would DUF files only show up in the non-runtime directories?
I thought the content library would show a DUF, as long as you could drill down to the directory, and refreshed it???
967 x 510 - 93K
Post edited by 3dOutlaw on
  • Richard HaseltineRichard Haseltine Posts: 100,833
    The Runtime\Libraries folder is for Poser content - if you place an empty "Poser" file with the same name (a 0 byte file with a .cr2 extension) in the same folder it should allow you to load the file but it's better to save in the DAZ Studio folders (that is, not in Runtime and not in Data).
  • 3dOutlaw3dOutlaw Posts: 2,471
    edited December 2013
    OK, I'll try the dummy file. It is a Poser prop, that I am changing the Shader...and it would be a pain to have the prop in two different locations...I would easily forget where I put the second copy. Thanks for the tip! I'll report back if it does not work.
    UPDATE: Added a empty text file called Tree3.pp2, and worked like a champ! Thanks again! :)
