When scaling a plane, is it possible to fix onle of the edges to not move from scaling?
I have a plane, posed vertical. I want to scale it to become exactly as another plane and at the same time the bottom edge to stay on the floor. Now I scale it a little bit, Ctrl-D, scale it again etc. So is it possible to scale it w/o the need to adjust it all the time with Ctrl-D?
(this is just an example to clarify my question)
  • Sven DullahSven Dullah Posts: 7,621
    Easiest way is to position the plane so the bottom edge is aligned with the floor. Then create a null object, parent the plane to it and scale the null object. Or you can position the plane, then export as .obj and import it. That will align the center point of the plane with the bottom edge.
  • …or you just move the origin point of the plane to the edge on the floor and scale then?!
  • handel_035c4ce6handel_035c4ce6 Posts: 472
    edited July 2019
    Is there a hotkey to move the origin to the floor?
    Also - is there a way to scale a plane to predetermined size?
    Post edited by handel_035c4ce6 on
  • L'AdairL'Adair Posts: 9,479
    edited July 2019
    I don't know of a one button solution, but you can move the origin/center using the Joint Editor Tool. You can locate it in the Tools menu. There is also an icon for it, probably in the top bar below the main menu. It looks like an "X" where one leg is a bone and the other a pencil. The following assumes you've created a plane using an X or Z Primary Axis.
    1. Select the Joint Editor Tool.
    2. Open the Tool Settings pane(tab). If it isn't docked, you'll find it from the main menu under Window > Panes(Tabs)
    3. Select your plane. You should now see indicators for center point, (green) and end point, (red).
      Joint Editor Tool 01
    4. In the Parameters tab, locate the Transforms for the plane. As you have moved the plane to the floor, (Ctrl+D), the Y-Translate value will be 1/2 the size of your plane, and the exact value you need.
    5. Select and copy the Y-Translate value.
    6. In the Tool Settings tab, locate the Center Point: Y Position and click on the value to make it editable.
    7. Paste the Y-Translate value here.
      Joint Editor Tool 02
    8. In the Viewport, right-click.
    9. Select Memorize > Memorize Selected Node(s) Rigging
      Joint Editor Tool 03
    10. Save your scene.
    You determine the size of your plane when you create it. After that, all scaling is done in percentages. There are a couple of tricks you can use that might help, though.
    • All values in Daz Studio can take simple math operators. Keep in mind, "%" is actually an operator, so to divide a percentage value by 4, for example, you would change "100%" to "100/4". when you click out of the field, DS will do the math and the resulting value will be 25%. This can be really handy if you want to scale several objects by the same amount but can't group them.
    • By default, the plane is created with X-, Y-, and Z-Scale at 100%. If you want to apply an image, using the plane as a backdrop to a scene, you can scale X and Y to match the ratio of the image and then use the overall Scale to control the size of the plane.
      • If your image has a 16:9 ratio, (HD), set X-Scale to 160% and Y-scale to 90%.
      • If your image has an odd size, maybe cropped from another image, you can use the pixels instead of the ratio. For an image 3152 wide x 1866 high, for example, set X-Scale to 31.52% and set Y-Scale to 18.66%. (Notice the decimal points. You can place the decimal point anywhere, actually, but if your plane is already 50 Meters, you probably don't want scale it 3156% by 1866%. )
      • Be aware that DS may change your actual values, but the ratio will remain the same.
    I hope this helps.
    Post edited by L'Adair on
  • Thanks a lot. Definitelly will help!
    I presume there is no snapping tool or function or whatever? It is PITA now to snap two surfaces to each other (for example making a room etc)?
    There is the Align tab. It does have some limitations, but it could help. You'll find it in the Window > Panes(Tabs) menu. I think it's pretty self explanatory for the most part. You select object that is staying put and then select the object to move. With both selected, you set the X, Y, and Z rules and hit the Align button.
    It does not work on surfaces, so you can't select the floor of a room and move something to set on the floor. It will set on the top of the highest point, which for a room could be the ceiling. But for putting planes together to create a room, it should be pretty helpful.
    edited July 2019
    LOL...  "Les Mystères de Paris"... I mean "Les Mystères de DS":-)
    Or said in another way - why have to be simply and easy to use when can be done complicated and hard to use?
    I asked around, and what you are looking for can be found in Tool Settings for the Transform tools.(Universal Tool, Translate Tool, Rotate Tool, Scale Tool.) Open Tool Settings, which can be found from the main menu via Window > Panes(Tabs). (I keep that pane docked, 'cause I use it a lot.) You can select the tool you need from the drop-down in Tool Settings, if it isn't already selected. About half-way down, you'll find Snapping. It is disabled by default.
    So in this case, it wasn't the program that was lacking, just my knowledge.
    edited July 2019
    Thanks again!
    Edit: You mean under Snapping there are 3 buttons, I need to click to the kind of snapping I need and to put the distance when the corresponding snapping is activated?
  • Richard HaseltineRichard Haseltine Posts: 102,742
    Thanks again!
    Yes, it's a snap-to-grid setting, which is how most of the snap-together sets work - they are modelled to as et unit size (not always the same one).
    Thanks again!
    As Richard answered the rest of the question, and he knows these things much better than moi, I just want to add only the Universal Tool has all three buttons. The other tools have only the relevant button.
  • IvyIvy Posts: 7,165
    you can try one of mine of my panes the axes are set at floor level so the scaling will do what your looking for http://www.sharecg.com/v/92902/gallery/21/DAZ-Studio/Ivys-Magic-Pane-prop
