Having Render Problems Carrara 8.5 Pro
Before going to bed last night I started an animation render and this morning I noticed that M6 wasn't attached to clothing or in proper pose. But if I render a single frame everything's where it belongs.
Link to video http://www.youtube.com/watch?v=MDgadHmyNW8
Attachments are single frame renders ~ frame 1, frame 60, frame 180, frame 300 and frame 420
I have a total of 600 frames to do and would hate to have to do it 1 at a time. Any Ideas?
853 x 480 - 437K
853 x 480 - 441K
853 x 480 - 406K
853 x 480 - 422K
853 x 480 - 454K
  • DUDUDUDU Posts: 1,945
    Cannot see your video, its a private video on Youtube...
  • edited December 1969
    Fixed
    In your video, clothing does not seem to be related to the character.
    In your photographs, it is only one minor problem which can be solved in modeling room.
    Select the bad zone of the dress (smooth selection) and you modify forms of this one.
    If there are large modifications during animation, I advise you to create a zone of deformation to correct this problem.
    I have never created a zone of deformation before.
    also in the video the clothing is doing exactly what I want it to. M6 for some reason isn't following the same path
    edited December 2013
    Usually, it is the clothing which does not follow the character…
    You are sure that it is well the clothing which is related to the character and not the reverse.
    Select your clothe and in the small framework “Animation group” on the right side, look at if it is well “ Fit to: your character”.
    For your character, “fit to: None”...
    Post edited by DUDU on
    This video could interest you: http://www.youtube.com/watch?v=JDiY2K-Higg&feature=c4-overview&list=UUgsInAR7sGNMJiX4i7dybrg
    yes the clothing is set to "Fit to: Genesis 2 Male" and Genesis 2 Male is set to "Fit to: None"
    In your video, your character is not animated, look if in the General tab, "Animated" is checked.
    But normally, clothing should not become animated either.
    I never had this problem…
    If your animation was made in Studio, someone else could help you...
    All animation is done in Carrara. And everything is set to be animated in the general tab.
    Very strange. Just out of curiosity, are you rendering to network? I have heard of strange things happening over render nodes. Since Genesis 2 is not fully supported in Carrara yet, it might have something to do with that (network thing).
    Other thoughts
    Perhaps some sort of collision detection setting that shouldn't be set?
    Perhaps there are key frames for clothing in addition to the Genesis 2 Male? If so, I would bet that they have a Bezier between them. If you really need those keys, try making the tweener linear instead.
    So the solution was so simple. I closed everything, ran a clean up and restarted my computer and re-rendered and it worked. lol
  • MiloMilo Posts: 511
    Was that cleanup something in your system or in Carrara (condense shaders etc?)
