The victoria support file could not be found
acedrakeacedrake Posts: 41
Salutations ladies and gents, I am installing v 4.2 but when I run daz and try loading victoria 4.2 it says Victoria support file could not be found. Same with Hiro 4 as well, it says michael support file could not be found. I am installing the files in the d: drive away from the c: drive. PLease help.
  • Richard HaseltineRichard Haseltine Posts: 102,168
    You should have \Runtime\Libraries\!DAZ\Victoria 4 in the folder you installed to, which should be a folder that appears under the Poser Formats heading in the Content Library pane - Window>Panes(Tabs)>Content Library (you won't see the \Runtime\Libraries\!DAZ\Victoria 4 folder in Content Library, but the folder it is in should be there with at least \Figures\DAZ People and Pose\DAZ's Victoria 4 in it).
  • SzarkSzark Posts: 10,634
    edited December 2013
    If what Richard said above is not the issue did you run the .bat files when your Installed M4 and V4? If not with DS closed go to
    \Runtime\Libraries\!DAZ > DzCreateExPFiles-M4.bat and -DzCreateExPFiles-V4.bat
    run all the .bats by double clicking on them one at a time.
    Post edited by Szark on
  • acedrakeacedrake Posts: 41
    Tried both suggestions, and still nothing. I even reset the database and re imported it and nothing.
  • JaderailJaderail Posts: 0
    Is your DAZ Studio set to LOAD the content from the folder you installed to as BOTH Daz Studio Format and as Poser Format? Is your DAZ Studio even set to see the DIM install folder?
    Yes they are set to load both formats and Daz Studio is set to see the DIM. All the other content is fine only hiro 4 and v 4.2 are the only ones that gives me the error of folder not found.
  • fixmypcmikefixmypcmike Posts: 19,597
    Can you post these 2 screenshots: ...
    1) In DS, Edit > Preferences > Content Library > Content Directory Manager, expand the "DAZ Studio Formats" and "Poser Formats"
    2) In DIM, on Ready to Install tab check the "Show Details" box in the lower right
    Here they are, the screenshots
    1920 x 1080 - 133K
    Umm we need to see these.... BOTH
    677 x 541 - 37K
    477 x 462 - 37K
    Post edited by Jaderail on
    Here is the other screenshot.
    1920 x 1080 - 716K
    You need to add D:\Users\Public\Documents\My DAZ 3d Library under Poser Formats.
    Those suggestion didnt work, but here is the error message
    1920 x 1080 - 735K
    I decided to install P8 and lo and behold the files are now working. weird, but thanks for the support guys and gals and do have a nice and merry Christmas and a prosperous new year!!!!!!
    Did you CLOSE DAZ Studio and Re-Open it AFTER you added the path? If not the PATH is not valid, it will only be READ at a OPEN. So adding the Path and then trying to LOAD the figure is still using the LOADED paths and will fail, it will ADD the new path and read it only at open. Or a FORCED Refresh I believe.
    Uninstall the Powerloader for V4 and the error should go away. You will just have to inject V4's morphs manually.
  • winmathwinmath Posts: 140
    Richard Haseltine said:
    You need to add D:\Users\Public\DAocuments\My DAZ 3d Library under Poser Formats.
    I had the same problem after I deleted a lot of folders. Adding My DAZ 3d Library back to the Poser Formats, moving the library to the top, and refreshing the content fixed the problem.
