Andy2 clown texture file.
TabbycatTabbycat Posts: 207
edited December 2013 in Freebies
Ok, this texture will texture the Andy2.obz file but it will be extremely faint.
You do this by going to the material room and applying this texture to Andy2. You do have to remember where
you saved the texture file on your hard drive when you download it.
Well hell bells, I want it not to be so faded. If you feel the same, you got more work to do.
You need to save Andy2.obz as a regular obj file. This is how you do that. Have Andy2.obz in your work area and you just
export it as an object or save it as an object file. REMEMBER where you saved it.
Now you need to make a UV map of that object file. I use the free UV mapper. Open that file in UV Mapper.
Once it has been mapped you save it twice, once as a model, the next as a UV Map.
Back in Poser, import either the model or the UV map into your work area. Apply the texture.
If you run into problems, I won't be able to help much but you are welcome to comment or ask questions here and I will do my
best to help.
Had to post the freebie here
http://www.daz3d.com/forums/discussion/34530/
Tabbycat
Post edited by Tabbycat on
