Daz Install Manager is not removing files during Unistallation
KeyKey Posts: 19
I always thought that uninstalling an item from Daz Install Manager will remove all related files from hard drive but that doesn't seems the case (at-least for me).. I have just uninstalled few clothing items and i can still see folders and all related files inside Daz 3D Library. Is it possible to delete all related files from hard drive when uninstall an item via Daz Install Manager? If i'm having this issue, any idea why?
  • NorthOf45NorthOf45 Posts: 5,553
    Is it really there? Try to load it. Try a refresh on the folder in Studio. Sometimes the displayed contents don't go away immediatley. Check the physical file system to see if anything is still present (right-click->Browse to File Location...). The only time I've had contents persist was if I had moved or renamed them for some reason.
  • KeyKey Posts: 19
    Yes. It's really there.. Uninstalled about 3 items and went to location with Windows File Explorer. All 3 folders were still there. Refreshed directory.. Deleted them manually from Peoples/Genesis 3 Female/Clothing folder..
    Did you change installation path or manifest folders in DIM at some point? Products could get re-installed to different locations if it loses track of the first one. Are DIM and Studio looking in the same folders for content? I know it sounds a little obvious, but, y'know...
