Fitting High Heels to the Gen Girls?
ThinkTank_7c984fcc32
Hello,
I modeled high heels (plateau pumps) for the Gen 2 Female in a "high heeled"-pose (as I find it hard to model them against the zeroed figure with flat feet).
But now of course can't find a way to fit them correctly...is there a secret to it? The transfer utility is just mocking me.:bug:
What is the best way to model and fit high heels for the Daz Genesis females? Is there a tutorial out there I'm seemingly unable to find?
Thank you for your patience!
If you apply the same foot pose to the Figure does that correct the issue? If not try the Foot pose then Parenting the shoes then save the shoes again as an asset once parented. You will of course need to have that Foot pose to apply each time you use the shoes.
Thank you for your answer!
But evertime, flat footed and pose footed, the shoes get deformed...as if the high heel pose is doubled on them.
Just parenting them doesn't work either, the moment the gen girl get's posed the shoes are left behind...
I will try the "saving as an asset" idea, thank you! :)
You should try this tutorial
http://www.sharecg.com/v/61954/browse/3/PDF-Tutorial/DS4-TutorialRigging-High-Heels-for-Genesis-rev1
It's what I used to get my shoes fitted to Genesis, so I would think the principle would be the same for G2F
Oy....that looks complicated...
Thank you!
Okay...my fault...missed parenting to the foot! That works as you said it would, thank you! :)
I find it easiest (less of a head ache) to model high heels for the default foot pose which is flat, its possible but takes a bit of practice, I know that wont help you on this occasion (sorry), but you might want to try it in future maybe?
It for sure would be so much easier even as I have still problems to figure out the eventual form using flat feet only...need more training! *sigh*
