Adding to Cart…
![](/static/images/logo/daz-logo-main.png)
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
I ran the skirt through the Fixer script anyway and added Hip, Large Zone Expanders, and Skirt moprhs. I played around with the skirt and it seems to be working ok. One weird thing - I wasn't able to add a smoothing modifier. Is that normal?
That is weird. Is the smoothing modifier already there?
Look for the tutorial in my signature about BEWARE THE SOCKMAN and it will let you know how make an .obj file into a piece of conforming clothing. :)
I am sorry. I just checked how Daz packaged up our product. For some reason, Daz split up our one zip file into two. You need BOTH zip files.
Thanks for the heads up, Riversoft. :)
Hi Riversoft & Sickleyield,
Just wanted to say thank you very much for this product. It's lightweight, fast, and adds some really nice options.
In using it, found myself wishing for just a few more foot and head morphs options. Like more positioning options on forehead line, or top front of foot, there is a zone that morphs just don't quite impact as much as other zones. The breast smoother iunclusion was great too, though a few more toptions would be great. Would buy happily an expanded version for this. Should you decide it's worth your time :)
As it is, use this alot, and add the "heavier" fit-on addons if needed.
Thanks guys.![smiley smiley](https://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/regular_smile.png)
You're welcome! I will mention this to Sickleyield (she is the morph maker
Hi there,
I bought this Item at April 10, 2020 and it's not really working. I always get the message that the files of the Ultimate Clothing Fixer are not found. I install manually but my content directory looks exactly the same like the file list in the documentation center.
Script: DAZ Studio\Content\Scripts\RiverSoft Art\Ultimate Clothing Fixer
Files: DAZ Studio\Content\People\Genesis 8 Female\Clothing\Ultimate Clothing Fixer
Unfortunately I can not find the error. Maybe someone has an idea what I have to change, that it works.
Is "Content" the name of a Daz Studio content library that is configured in the Daz Studio Formats section of the Content Directory Manager?
Exactly. And I always make sure that all the folders in my library are named the same as the folders in the ZIP file. That's why I don't understand why the files cannot be found.
Sorry for my bad english. I'm from Germany.
What is the exact error message? I need the Daz log to figure out what is happening.
Hi River,
here the message of the log file:
2020-04-19 07:35:09.804 Loading script: E:/DAZ Studio/Content/Scripts/RiverSoft Art/Ultimate Clothing Fixer/Ultimate Clothing Fixer G8.dse
2020-04-19 07:36:05.994 DEBUG: Conformers Directory: People/Genesis 8 Female/Clothing/Ultimate Clothing Fixer/
2020-04-19 07:36:11.854 WARNING: QString::arg: Argument missing: <p>The Ultimate Clothing Fixer script fixes clothing fit problems fast, easy to use, and saves fixit morphs right into clothing! Where projection morphs require you to dial from the body of Genesis 8 and are limited to the figure shape, this script builds the morphs you choose from our list into a clothing piece right in your scene, then saves them so they can be used right from the clothes. The innovative conformer-based morph solution also lets you add skirt morphs!</p><p>Not only that, but additional workflows also let you achieve "just for one scene" quick solutions if you don't want to save morphs in every clothing piece that needs clipping fixed.</p><p>How to use:<ul><li>Select your clothing item</li><li>Start the Ultimate Clothing Fixer script</li><li>Select your clothing item</li><li>Select the conformer you want to transfer morphs from</li><li>Select morph areas to transfer</li><li>Optionally, specify if the transferred morphs should be saved</li><li>Click Accept</li></ul>, Male or Female
2020-04-19 07:36:11.874 WARNING: QString::arg: Argument missing: , Genesis 8
2020-04-19 07:36:11.874 WARNING: QString::arg: Argument missing: , Male or Female
2020-04-19 07:36:13.724 Script executed successfully: E:/DAZ Studio/Content/Scripts/RiverSoft Art/Ultimate Clothing Fixer/Ultimate Clothing Fixer G8.dse
I watched the video from Sickleyield to be sure I follow the correct steps to use. After running the script I get the error message and the window for selection the figure you want to use pops up empty
Unfortunately, I don't see the error in the log. Those warnings can be safely ignored. Does an error dialog display?
