Material preset not working with figure
I am pretty new to Daz now using for about a year and still learning. Using current, 4.11 and updates.. Recently I purchased Cassius and NecroGothica HD. NecroGothica HD will load the Set with the cave, however it remains grey like if it was just Zbrush. The material presets that come with it will not work. In my scene tab display I make sure highlight the Necro set and then click on a material preset color, they give 3 options. I even click merge into scene and will not work. There is an egg prop that comes with it, the materials load fine for the prop but the Environment Cave will not load material duf to change color??
In Cassius Alien Daz Dog 8 figure , it will only load the default material preset purple blue onto the actor. If you want to change to the other material color presets , will not work. I have to go into the surface tab and change the base color.
I have not had any problems with any other materials for figures , scenes, just these 2. Thinking there is a problem from the files from the vendors?
Ithink Necrogothica has custom 3Delight shaders which won't preview or work in Iray.
Cassius does say in the read me that the other colours need Iray render or preview to show.
Thanks for the help, I missed that with cassius. I have had nice success with using the material files from many other daz dog characters. With the Necrogothica I guess working with Iray then is not good. I am able to adjust surface ambient for some shade but still is not fully textured. Wonder if there is a work around, or I can apply some other material and shaders like I can do with Cassius?
