GOZ for bridge from daz studio4.6 to zbrush not working.... grrrr... pls help! - part 1
hi there....
i have download zbrush 4R6 yesterday.... it´s an amazing tool...
BUT: the bridge does not work....
if i try to send something to zbrush daz tells me it´s unable to connect with zbrush and i should check the installation
here are some hardfacts to discribe the surrounding of the problem
i am using mac and run 10.6.8
daz studio 4.6
zbrush 4R6
GoZ 1.3.1.39
GoZ is active/ loaded in daz
in zbrush the path to daz seems to be correct
i have read many threads in several forums to locate the problem...
looks like i am not the only one with trouble
i uninstalled everything and re-installed following these instuctions (for win) that i have found somewhere
- Download a single installer for zbrush 4.5
- Download latest version of DS 4.6.0.18
- Download the latest version of GoZ for DAZ Studio 1.3.0.8- Uninstall DS
- Uninstall GoZ for DS
- deactive zbrush
- Uninstall zbrush
- manually delete all remaining files in C:\Users\Public\Pixologic- Optional: use a software like CCleaner to remove unused references and clean the registry
(Update /Edit: Thank you Natasevol for confirming that this step can be skipped)- reinstall zbrush
- activate zbrush
- reinstall DS
- reinstall GoZ for DS
i don´t know what else to try
PLS HELP!!!
i´ll post some extra screenshots in following post to make the case more clear
here are some more screenshots to show the enviroment of the problem
the path is correct - i think?
just uninstalled and reinstalled everything again... with no difference... of cause :(
one more info photoshop goz installaion does also not work... in this case the error is that the path could not be found!??
ok.... i have updated goz for zbrush and now it works!!!! happy!!!!
