switching heads
Is it possible to switch heads from one character onto another character's body?
  • LeanaLeana Posts: 11,835
    edited September 2019
    If you mean textures, then usually no.
    If you mean shapes, it depends: Some characters are provided with separate head morph and body morph, in which case it’s easy to mix them with other characters. Some are only one morph with both head and body (for various reasons, like for example the head requires a neck morph too to look ok), in which case you can’t use only the head or only the body. There are utilities to split full body morphs, but you’d lose the HD details if there were any.
    edit: I assume you meant characters for the same figure, not G3F head on G8F body for example.
    Post edited by Leana on
  • Yes I noticed I have a few characters with individual head and body morphs, however when I select the head of one character and choose 'apply head morph' from another character, it does not replace the current head with the new one it just creates something horrible looking instead.
    You probably need to remove or zero the head morph for the first character first, the preset for the second character can only zero the morphs the creator also had when saving it, it can't account for every morph possible or any which would be created in the future.
