Dorm W.I.P. in need of some help (lighting & other)
Turk_WLFTurk_WLF Posts: 177
edited January 2014 in Carrara Discussion
I’m working a dorm room with real world and scale 10’ x 15’ 6” with 8‘ceiling, it’s currently layout just to give the feel of the room.
What I need help with is the lighting which is just a bulb (bulb light) in the center of the room at the moment. My goal is to make it as realistic as I can.
Later on I’ll need help with making the walls look painted & how to get the wood to look correct for the piece.
(it's a night scene)
Thanks,
640 x 480 - 20K
640 x 480 - 21K
640 x 480 - 21K
640 x 480 - 20K
640 x 480 - 16K
Post edited by Turk_WLF on
    What is the goal for the scene? An animation, a still render?
    Looking cool so far!
    Many might disagree with this technique, but I'm throwing it out there anyways in case you might like it.
    For light fixtures, like the one I see on the ceiling, I prefer to use a spot light instead of a bulb. Then I set the angle to 90 and the angle falloff to around 30. Then I'll set the distance to 30 feet with a falloff set high, like 60. Distance and falloff for distance need tweaks according to the room and what sort of effect you want. But now we don't have any light on the ceiling. So I duplicate the spot and flip it, reduce the distance and brightness. Both of these lights need to be low enough to not touch the mesh of the fixture, unless you set it to ignore the fixture - I prefer to just place the lights below the fixture. Note that you can get closer and closer to objects the smaller you scale the lights.
    Really like your modeling though. The scene is really looking great!
  • Turk_WLFTurk_WLF Posts: 177
    I'm planning on using the scene/set as a still for the time being with the hopes of using it as part of an animation when/if I get the other pieces done. The beds aren't my work just fill-ins until I get things done.
  • Design AcrobatDesign Acrobat Posts: 459
    You may want to consider IES lighting based on real world lighting which is in Carrara 8.5 Pro and some earlier versions.
    Here is a tutorial:
    http://www.cgarena.com/freestuff/tutorials/max/ieslights/index.html
    The above tutorial can be found in a link at:
    http://3d.about.com/od/Creating-3D-The-CG-Pipeline/tp/8-Tips-To-Increase-Realism-In-Your-Renders.htm
    This is a helpful learning tip page to consider:
    8 Tips to Increase the Photo-Realism in Your Renders
    Easy Techniques that Will Make Your 3D Renders More Realistic
    Thanks for those links, DA! Very cool stuff!
  • HeadwaxHeadwax Posts: 10,097
    hello
    each surface will reflect light at a certain colour so that is something to think about - also caustics for the mirror
    this reflected light will effect shadow colour as well
    I love this link :http://3d.about.com/od/Creating-3D-The-CG-Pipeline/tp/How-To-Make-Really-Bad-Cg.htm
    Note well the part about coloured light
    and also some random quotes from http://forums.cgsociety.org/archive/index.php/t-404342.html
    Don't be afraid of using the light falloffs, inverse square is a natural falloff. Get used to using area lights and spotlights.
    Avoid ambient lights as much as possible they will wash out an image, it doesn't look like GI (apart from GI in certain Arch Vis. renders that's so washed out that really they could have saved the time and just used an ambient light).
    Use color in your lights, natural light is never ever pure white, it's always slightly yellow, slightly blue, slightly this or that, it's also frequently brighter than 100% in the illumination tab, use the lights brightness setting.
    Experiment with the color correction post effect to modify your Gamma, try a range between 1.6 and 2.2 for a more natural looking effect.
    Learn to place your lights well, use the Look through selected option to help in the editor, always remain true to your scene, if light should come from a source then add it, if it shouldn't then don't have it there.
    I always use colored key lights, making sure that I also choose a complementary color for my fill, and continue this trend with each light I add to my scene, pairing a contrasting colored light with each added light. For instance, if your key is yellow or orangeish--I go with a soft blue, or slightly purplish fill light.
    Adding several subtly colored lights to a scene can really help add depth to your image--and sometimes may even help your image begin to approach an almost GI look (treaded carefully on that comment.) :)
    I don't agree with not faking lighting, and don't forget about post work
    you could also try making your room an anything glows object with a small radiance eg 12 percent to get a base lighting - and see what happens
    for the wood - there's nothing like a texture map of real wood to look like real wood.
    If you are doing still images Vs. animation, the lighting set-up will vary.
    A longer render time for a still image won't fly for for an animation. With a still image, you could enable Indirect Light. You would still want to keep in mind the light sources and such, but you could get some nice effects at the cost of longer render times.
    With the animation, you would want to simulate Indirect Light and place low level, high fall-off lights to simulate reflected light. Carrara's scene wizard has some nice indoor sample scenes that utilize IL and caustics, as well as one that fakes it. It may be worth the time to take a look at them.
    Personally, I try and avoid GI in general. If I'm having issues, I may render a low res version and use that as a guide to place the lights that I want to simulate GI, then render the larger version without it.
  • PhilWPhilW Posts: 5,148
    For interior lighting, I think that it essential to use the gamma correction = 2.2 so that you are working as much as possible with a Linear Workflow (see http://www.daz3d.com/forums/discussion/25644/ if you haven't been following that discussion).
    My other recommendations would be to ensure that the Ambient Light brightness is set to zero, use full Indirect Lighting which will model the light bouncing off objects in your scene (it's faster to render than you may think if you haven't used it much). For the light sources, I have had a lot of success using models with glow turned up (so use the 0-10000% slider and set to between 1000 and 10000%, multiply by a color if you want a colored light). (Note this only works with Full Indirect Lighting turned on). A light bulb can be a simple small sphere unless it is to be seen close up, when a bit more modelling may be in order. Place this where any real bulbs would be and see what that gives you. If you are getting dark blotches in your lighting, turn up Lighting Quality in the GI panel to Best (again the render time hit is not that great).
    This may be my older system talking Phil, but I disagree with the time hit using IL. I think overall image quality can be improved by learning to simulate GI, both for still image and animations. The advantage for still images is less time to render and less image artifacts like ashing which can be an issue even with the best GI settings.
    I agree that sometimes you need to simulate GI, especially if your frame render rate is getting too high for animations. The downside is that it takes longer to set up, and the results will never be quite as accurate, because however clever you are in placing and setting your extra lights, there will always be some subtle effect of the GI that is virtually impossible to imitate. Each artist needs to make their own decisions, on an image by image basis, based on what works for them to get the output they desire.
