Losing Expressions when Rendering
in New Users
I've tried several times to render a G8 Female with a frightened/surprised look, and I move the eyeballs to the left and down and when I try to render I lose the expression. It goes back to neutral. Any ideas what's going on here? I'm using Daz 4.12 and Iray.
If all you're doing is moving the eyeballs, is it possible the lighting is creating an illusion that the eyes are pointing one direction when they are not, due to the reflected light?
Can you post both the Viewport and the render?
You can save the viewport draw from the file menu, no special software needed. Go to File > Save Last Draw… and save the file to somewhere easy to find, perhaps where you're saving the render to. Then attach both the draw and render images to the post.
It would really help a lot if we can see what you're seeing.
