Animate runway wip
I'm working on learning more about animate and camera movement in a scene. Here it was somewhat on accident, but a good one. As I move about the scene adding lights though, is there a better way (I'm usually in perspective view) than using the Pan tool? Holding down the mouse and moving over and over is quite tendious and sometimes not fully in the direction I want. For example, moving to the left as the subject does, but at an angle that gets further away from the path she is walking.
Thanks for any feedback.
  • nonesuch00nonesuch00 Posts: 18,288
    You can:
    a) select an object in the & use the camera/scene focus square cross hair thing.
    b) or add a bunch of nulls distributed where you want the camera to track and position them by type in numbers instead of using viewport (when I do something like this I try to place everything according to no decimals for the X,Y,X as much as possible and even better when possible I try to use number that end in 0 or 5, not always possible but when it is it is simplifying).
  • brainmuffinbrainmuffin Posts: 1,213
    What about creating the needed lights? Moving around to place them is quite a pain.
    You can:
    Thanks. That helps with the camera.
