What's wrong with this clothes?
lord Adamlord Adam Posts: 125
I load figure form DAZ Kids 4 but there is a problem with clothes...I don't know how to fix this??
Maybe this clothes are mismatches and I should look something else in content tab?
770 x 1079 - 76K
    Sometimes all you need to do is to select each clothing piece in turn, and Fit-To (just above in the right panel when the clothing figure is selected) the figure again. It will run through and refit them.
    In the old days of poser you just turned off the visibility of that body part. Why have visible legs under a pair of pants? It just means the pants mesh has to be bigger... Shoulders have to be baggy and huge to encompass the full range of posing, but if there is no skin visible from the neck down why bother?
    Old days? Hmnpf! I still do that all the time ;)
  • MadbatMadbat Posts: 382
    Yup, vanishing bodyparts can be your friend. Apply Smoothing Modifier can also help, I've used that on clothing on V4. Usually it can be left at the default value, otherwise you usually only need to nudge up smooth and collision values by a few points.
  • lord Adamlord Adam Posts: 125
    I forget to mention that this problem is supervene in Carrara Pro 8...
