weapon in hand ?
Thadeus72Thadeus72 Posts: 411
hi
is there a solution to put some weapons directly in the hand of the characther
because for some products it doesn't work and i 've done it by myself
i think about adariel for v5 or heracles ... when i click on the weapon it appears on the feet ...
i use ds 4.0.3.47
thanks a lot
  • Richard HaseltineRichard Haseltine Posts: 101,901
    What you might try is parenting the item to the hand with Parent in place off - if you use the Change Parent dialogue it's a check-box at the bottom. That way the item's origin will align with the hand's, you will need to adjust but as long as it was modelled square on that should be relatively easy if you go to Tool settings and change the axis setting to Use Local Coordinates or Use Object Coordinates
  • Thadeus72Thadeus72 Posts: 411
    thanks a lot richard i will try
