Issues with creating objects from lines
GoshtacGoshtac Posts: 0
Hi folks;
It has been awhile since I used HEX ( Couple of years due to lack of decent computer ) Now I have gotten back into my 3D Art and have HEX 2.5 installed on my newest system ( WIN 7 Pro - 64 Bit / HEX is installed in an x86 program file )
Perhaps I have just turned stupid over the past few years or perhaps it is an issue with HEX and my system, but I used to be able to take a poly line and or Helix and create an object file from them and export to other programs such as Bryce and DAZ Studio. I used to make various cables and wires for projects doing this.
But now, I cannot get any lines I create in HEX to do anything and it won't turn into a solid. Primitives work fine in HEX, but the various line commands don't seem to do anything other than sit there after I make the initial shape. Am I missing something that I used to do but have forgotten along the way, or do I just have an issue between HEX and my new system. I know it should work, as in the past I posted quite a few freebies of cables, etc. I made this way, but just can't figure out what I am doing wrong. I have tried validate, apply, etc to no avail and even did an uninstall and reinstall of the program. ( Trying to select all and group did not do anything either )
Appreciate any thoughts on what I might be missing in the way of some steps here that I could have forgotten? Thanks and have a great day....
Signed: Dumbfounded in MI ;-) / Bruce aka goshtac
  • ben98120000ben98120000 Posts: 469
    Perhaps adding Thickness from Surface modeling menu.
    1024 x 768 - 302K
  • RoygeeRoygee Posts: 2,247
    Most of what I do starts off with a polyline of some sort and I have the same set-up as you (except that my Hex is not installed in X86) so it definitely works.
    It does depend on what type of polyline you are using - some have to be validated and DG collapsed before you can do anything with them - could that be the problem?
  • GoshtacGoshtac Posts: 0
    Thanks guys for the responses
    Yup - It was the thickness setting I forgot and this solved the problem. After being away from my software for 2 years, I just had to relearn a few simple steps.
    Thanks again and have a great week!
    Bruce
