Projecting Image on Camera
subtl3subtl3 Posts: 46
I have a scene with windows, trying to project a jpeg picture as an outside view...
Is there a way to load it to camera?
  • TjebTjeb Posts: 507
    If you have image edting software, I would render to .png and put in the background in Photoshop, Paint Shop, Gimp (free).whatever you have.
  • Cayman StudiosCayman Studios Posts: 1,136
    Create a plane (Create > New Primitive...). Rotate it 90 degrees, position it behind the window, and add the picture in the Diffuse channel via the Surfaces tab.
  • FirstBastionFirstBastion Posts: 7,850
    The plane suggested above is a very good method. An alternate is under the edit tab, load the image as a backdrop, it should serve your purposes.
    239 x 349 - 23K
  • masudaijaz291masudaijaz291 Posts: 4
    Use Photoshop to edit the picture and save as JPEG.
  • subtl3subtl3 Posts: 46
    Thanks for the suggestions guys, I was using Photoshop . . . but it takes time to separate it from hair
    So I was looking for some planar projection kind of thing, thanks again!
    Ended up using @First Bastion way just what I need! thanks!
