Issues installing Teen Josie 6 pro
PookPook Posts: 121
I've probably done something really stupid and missed a step somewhere along the line. I've just picked up the Teen Josie 6 Pro set from the store and installed it in my Runtime (I've got a complicated setup - Genesis stuff are in their own folder!). Everything seemed to install correctly, however when I tried to load the Teen Josie 6 base figure in Daz Studio I get the following missing file error:
/data/Age of Armour/Subsurface Shaders/AoA_Subsurface/AoA_Subsurface.dsf
And at that point, she loads with a plain grey skin. I also get the same missing file error if I try to apply the skin separately as a material.
I checked the file list for the Teen Josie character and it doesn't seem to be one of the installed files, so I'm a bit confused! Can anyone shed any light?
I apologize if this appears as a double post, I wrote it once then it didn't appear after I hit "submit" so I've got no idea if this is going to be a replicated post!
    You need to install "Default Lights and Shaders for DAZ Studio". It's a separate item in DIM, or in your Product Library a separate download on the "DAZ Studio 4.6" page.
  • PookPook Posts: 121
    Fantatic - thank you - that solved the problem :)
    I'll be honest, originally I wasn't using Daz Studio, just Poser, so skipped that install - but now I've found it's easier to work the first part of the job in Daz Studio, save the file and then use the DSON loader to load it into Poser to finish the work
