Object import problems
![wsxc](https://secure.gravatar.com/avatar/a1214f7e20afaf5a977e26dbdc054306?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Fa1214f7e20afaf5a977e26dbdc054306_100.png)
I'm trying to import my DAZ Studio scene (.duf) to Carrara 8.5. Everything is well excepts one thing: I can't import Scoopback MiniDress and it even cause the Carrara crash. When I deleted that dress, import was succesful.
Here's the log:
Warning: duplicated in file \People\Genesis\Clothing\Scoopback Mini Dress\Scoopback Mini Dress.dsf
Warning: file /data/DAZ 3D/Scoopback Mini Dress/Scoopback Mini Dress/Morphs/DAZ 3D/Base/ADJFlower.dsf could not be found
Warning: Scoopback MiniDress duplicated in file \data\DAZ 3D\Scoopback Mini Dress\Scoopback Mini Dress\Scoopback MiniDress.dsf
Error: node /data/DAZ 3D/Scoopback Mini Dress/Scoopback Mini Dress/Scoopback MiniDress.dsf#Scoopback MiniDress not found
What to do?
Is it dynamic? Otherwise it looks as if something with it couldn't be found. Is the file path broken?
Carrara 8.5 doesn't like duplicated files .
Nope. Not dynamic. I don't have C8.5 or .duf so what help I can offer is limited. You could attempt to re-export from D/S and try and import the new file into Carrara.
are you getting a warning from DS that you have duplicated file for Scoopback MiniDress ?
if you are it will not work in C8.5 .
Well, you got it into .duf format once right? Just do it again, following bigh's advice on not using a duplicate. I can't really help beyond that. Sorry.
it will work if you don't have duplicated file .
is this one you mean - I did this render in C8.5
Yes, it is. I've just found a script that fixes duplicated files. It helped, and now I can import the dress. The only problem is that it appears as grey object and I can't use "Materials" subfolder to set the texture.
great .
are you trying to set texture in C ?
do it in DS - works better .
great .
read you post again - you want to open , not import
once you get in C - you can change texture using smart content
just did it .
hope this help .
