Can You Make A Multi Part Prop In DS4.0 Without Rigging?
I am working on a lamp prop with no moving parts. I want to be able to control what parts of the lamp that cast shadow. As it is not possible to to control shadow with the default material and I don't want to use special shaders, the "Cast Shadows" button in the Display menu of the Parameter tab would be a good option. But then the prop has to be split up in several parts so you can select them in the Scene tab. Making a separate dsf for each part seems a bit sloppy and having to rig a rigid object like a sever overkill. Any options?
Cheers! Oom
400 x 400 - 64K
Post edited by Oom Fooyat on
Well, if it isn't meant to be posable just lock all the transforms (set respect limits to on, and set the min and max values to 0) and ignore the weight maps and joint cnetres, other than the origin of the whole item, entirely
It is a long list of extra steps to add functions and then disable them. I even had to make it TriAx weight mapped to be allowed to save it. Why do DAZ hate simple props?
After finally making a figure out of the lamp it turns out it did not do what I want it to. The figures Cast Shadow is only controlled by the root, the button is there for each part but it do nothing, If that is a feature or a bug is a bit hard to tell, the Visible in Render button works for each part so I am leaning towards the bug side.
Well, I'm back at square one.
It looks like it is impossible to do this in DS unless I take that hideous detour of poor fix for bad design and save the lamp as a scene :sick:
Any one with better suggestions or do I have to track down a friendly Poser user to create a pp2 for me?
Cheers! Oom
Hi Oom...
Now I haven't tried this myself, but I assume you want to make the lamp a DS prop, parent all of the sub-objects to a main object and then Save As > Support Asset > DSF Figure or Prop file.
I know you can do this with .pp2's, just not sure with DSF prop, like I said, haven't tried yet. There's also the OBJtoPP2 script for DS3, but I haven't tried it in DS4 to see if it still works.
Hmm... don't know if this was of any help or not... :-S :)
Try using Legacy/Parametric rigging and see if that enables the shadow option on individual bones - in a TriAx figure the mesh belongs to the root, though I would have expected the code that allows bone-visibility to work to have enabled bone-shadow casting options too.
Ehm, just parent the primitives to one another. No need to make a figure at all.
Thanks for a good try but same old, same old. Visible in Render works for the bones, Cast Shadow dose not.
I agree, as the button is there you would expect it to work.
Cheers! Oom
I'd make a bug report/feature request to have the sahdow setting work for bones- not that it helps you now, of course.
How? There used to be a sticker or announcement on reporting bugs, I can't find it.
Make a bug report (requires a separate account if you haven't yet set it up) and select Feature under Severity.
bugs.daz3d.com is the Bug Tracker
