Daz 4.6 not saving camera angles like in previous daz versions?!
SoftAnnaSoftAnna Posts: 13
edited February 2014 in New Users
Hello, how do I save the angle along with the scene in Daz 4.6?
the old Daz did this automatically, but I'm not sure how to do it with the new daz.
Post edited by SoftAnna on
  • SloshSlosh Posts: 2,391
    It seems to me that camera angles are only saved if you use a camera other than the default "perspective" view camera. You must add a camera to the scene and that will save with the scene. Also, when you reopen a scene, it will open on the camera you had selected when you saved the scene. If that is the perspective camera, it will load in the default position, not the last position you had when saving. Only "added" cameras will store the positions.
  • SimonJMSimonJM Posts: 5,997
    Also, unless you Lock the camera then DoF-related settings will be lost on re-load.
  • TotteTotte Posts: 14,089
    You need a "Camera", the perspective camera is reset to default position when scene is loaded, I've asked before, this is intended behavior.
    Post edited by Totte on
  • McKinnanMcKinnan Posts: 0
    Once I load a new Camera and get it positioned just how I want it, I lock that sucker down with Parameters!
  • Richard HaseltineRichard Haseltine Posts: 102,730
    Ds3 created a new camera in new scenes, which is why the position was saved. You can tell DS4 to do that in Edit>Preferences>Scene
