I guess that the easiest way is through the 'Resolution Level' property. If we are talking about Genesis figures, this property is in the 'General/Mesh Resolution' group, and the name is "lodlevel". This is an enum property, taking 0 value for base resolution and 1 for high resolution. The script should be something like:
(function (){ var oSelectedNode = Scene.getPrimarySelection(); //get the main group tree var aAllGroups = oSelectedNode.getPropertyGroups(); //check if propery group exists if (aAllGroups.findChild("General/Mesh Resolution") != null){ //take all the group properies var aProperties = aAllGroups.findChild("General/Mesh Resolution").getAllProperties(); var oProperty = null; //iterate over the properties for (var i=0;i<aProperties.length;i++){ //check for resolution level if (aProperties[i].name == "lodlevel"){ oProperty = aProperties[i]; //done here break; } degug(aProperties[i].name); } //if the property is found if(oProperty != null){ //it is a enum property with value of 0 for base level //and 1 for high level oProperty.setValue(0); } } })();
I stored the property into the oProperty variable for any use.... Setting its value back to 1: oProperty.setValue(1); you will have high resolusion again
Works great, thanks so much!
The sample script http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/properties/node_properties/start is relevant here
