morph and move
laverdet_943f1f7da1
Hi!!! I have a problem: I have an object, imported from zbrush, then grouped with other objects and setted in my scene... then I want to make a morph , with this object, so I export from carrara into zbrush, modify it, and export as number 2 geometry... back in carrara, in the modeller room, I seclect the object, create a morph area, and so on... it's ok and works, BUT once the morph applied, the object jump at its first imported place... is it a way to solve that???
When you import your object, you center his hot point?
