Faceshop 8 WIN & Photo shop bridge
konkon Posts: 389
Does anyone actually know how to install any of this stuff? Daz support is worthless so is there anyone who can give me some real help?
    What problems are you having with the Photoshop Bridge?
    The easiest way is to use DIM, if that is what you are doing, what problems are you having?
  • konkon Posts: 389
    DIM? Photo shop bridge ask for a destination I have done that and it still doesn't work and Face shop does not download with DIM
    Do you have a compatible version of Photoshop. The bridge doesn't work with all versions of PS.
    You must click on the little 'gear' icon at the top right of the DIM interface, then select 'Applications', and enter the path to your version of Photoshop, so that DIM knows where it is. It also only works for CS4 or higher as chohole has pointed out.
    I don't know anything about Faceshop, but according to the product page, it is both a plugin for DS AND a stand alone program.
    Go to your 'My Account' area, find Faceshop in the list, and the page that appears will offer you downloads for both Manual and DIM. You probably need the Manual one for the stand alone version.
    edited February 2014
    A few requirements for the bridge:
    If using with DS4 or higher, you need Photoshop CS4-CS6. It does not work in the CC version.
    Daz Studio, Photoshop, and the bridge all have to be installed as either 32 or 64 bit. You can't use say Daz Studio and Photoshop 64bit with the 32bit bridge.
    As Jimmy said, DIM is the easiest way to install the bridge, but you need to do some setup first.
    In DIM, click the cogwheel in the upper right and go to the Applications tab.
    Note there is a default Daz Studio install location there. If this isn't the same path as yours, highlight it and click the - sign in the lower left of the window.
    To add an app:
    Click the + sign in the lower left of the window.
    Select the app in the first drop down, the installed version in the 2nd drop down, and the bit the app is installed as in the 3rd.
    Finally click the ... button to the right of the blank "text" box and browse for the path.
    All paths are pointed to primary install directories, not sub directories such as Plugins, etc ( ie C:\Program Files\Adobe\Adobe Photoshop CS6 (64bit) )
    Post edited by Lissa_xyz on
  • konkon Posts: 389
    I have done the settings and made the path for photo shop bridge in plugins nothing still ask for a path. Face shop tells you how to install but it doesn't install even after it says its successful!
    1920 x 1080 - 398K
    Can you please post a screenshot of your Applications tab in DIM, so that we can see what you have entered.
    Are you using CS4 or above?
  • Richard HaseltineRichard Haseltine Posts: 102,735
    On the bridge, did you set the path in the Applications tab and did you tell it it was the Photoshop path - you have to pick the application and version as well as the location, which for PS should be the main folder not the plug-ins folder.
  • konkon Posts: 389
    ? So wait I need adobe photo shop to use the photo shop bridge?
    1920 x 1080 - 1M
    1920 x 1080 - 1M
  • konkon Posts: 389
    I can't do a screenshot at the moment cause it won't let me while I am installing. I clicked plugin and it still ask for a path
    1920 x 1080 - 136K
  • konkon Posts: 389
    I really don't care that much about the photo shop bridge but Face shop I need to install
    1920 x 1080 - 1M
    Uhm, yes.
    You can't bridge to an application that you don't even have.
  • konkon Posts: 389
    Ok well I thought I had adobe installed with this laptop. Question so adobe opens things even with out me having adobe? So I need to buy adobe Photoshop?
    Yes, the Photoshop Bridge needs Photoshop CS4, C5 or CS6 and GoZ needs ZBrush - if you don't have those don't install the plug-ins.
  • konkon Posts: 389
    Like I said I don't care to much about the photo bridge I really need help with face shop. I don't want to make a ticket I hate asking Daz support stuff. :(
  • konkon Posts: 389
    What the **** I can't even download adobe Photo shop it gives me creative cloud this is getting stupid.
  • konkon Posts: 389
    HAHAHAHAHAHA! I GOT FACESHOP TO WORK!
    I think you will find that direct from Adobe you can now only get the Creative Cloud version, however it is still possinble to buy Photshop from some software retailers. like this one http://www.zoom4u.co.uk/adobe-photoshop-extended-cs6---pc---2675-p.asp
    You can still buy CS6 from Adobe themselves.
    http://www.adobe.com/products/catalog/cs6._sl_id-contentfilter_sl_catalog_sl_software_sl_creativesuite6.html
    You just have to read the small print on the CC membership plans page to find the link.
  • konkon Posts: 389
    Thank you but it seems like waste of time doing all that for a photo editor.
    If you just need a photo editor and don't care about the bridge, try something like Gimp.
  • konkon Posts: 389
    whats Gimp? most of the time I just use paint lol.
    Free and open source Photoshop alternative.
    http://www.gimp.org/
    No, the bridge will not work with it. lol
  • konkon Posts: 389
    thank u
  • info_b3470fa520info_b3470fa520 Posts: 897
    Just curious: Have you tried Faceshop tech support?
    [email protected]
    650-302-0894
  • konkon Posts: 389
    it works now thanks
