Ghost like hair that hides the entire face like Sadako's
![Cyberdene](https://secure.gravatar.com/avatar/71cf62181b5e288a140edf41ce61433a?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F71cf62181b5e288a140edf41ce61433a_100.png)
I've tried just about every site that sells DAZ content and still no one has bothered to make a long hair style that covers the entire face similar to Sadako from The Ring? Why hasn't anyone done this yet? I have at least two long hair styles that look like they had such morphs but neither of them did. It would be cool if someone actually made that hair. Except I would like it to be able to be both the length as seen in that pic and longer. I bought the wild wind hair assuming it was able to do it but no luck. I know these suggestions are usually pretty pointless, would be so much better to just make the suggestion directly toward the Vendors. I do it all the time on Renderosity and Rotica when I need/want something made, and most of the time they will do it or at least consider it... DAZ honestly need to come up with a way for us to do this...Its a shame you cant contact vendors. I know quite a few that made props for me when I asked them to or light sets even.
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/b8/687fa7af89f9fb5cdcfba1bc1a57bf.jpg)
Could you load your hair like normal then unparent it from the figure, rotate the hair 180 degrees and reparent it? You could the use any hair you wish.
Gus
Should be fairly straight forward to make a strandbased hair like that...
Not a bad idea; I once used braided hair as a dwarf beard by creative placement. ;)
One of Phil W's hairs would do the trick; the strand-based one. Can't look atm.
Linday's Classic Long Hair with dForce - https://www.daz3d.com/classic-long-hair-with-dforce-for-genesis-8-females (posed her with neck/head bowed down then simulated hair and raised head back to normal)
dForce Granny Nightgown - https://www.daz3d.com/dforce-granny-nightgown-outfit-for-genesis-8-females
